Thread: Lipo sacks
12.29.2008, 03:39 AM
I don't think it matters what you use to charge lipos in as long as the following guidlines are met:
> Container should absorb a flame up, not contain it. There should be breathing holes to vent the pressure.
> Container is non-conductive. If the wires happen to touch a metal object at the same time, it could CAUSE a problem. This may be true if there are holes drilled and the wire insulation chafes.
> Container should be able to dissipate enough heat, or insulate the heat, in a flame up to not catch fire to whatever it is sitting on.
