12.29.2008, 04:43 AM
1. All the combos are a v3 esc
2. Switchs still come on them. the majority of us remove them because they are a trouble spot
3. Doesn't matter where you plug the wires in, if it goes backwards just switch 2 of the wires
4. Don't know what the screws are for
5. download CastleLink from castlecreations.com
6. All the CC escs program the same so yes the manuals are basically the same
7. Once you hook everything up you'll know what is on and off on the switch if you keep it - best bet though is to cut the switch off and solder the wires together and cover it with shrink wrap
