dangerwr
12.31.2008, 05:14 AM
Originally Posted by ssspconcepts View Post
Are you sure the Infero GT bodies will fit? The Inferno chassis is an inch or so shorter than the DM-1 Spec. I lined up the stock Proto Form PF8 GT body on my DM-1 Spec and there just isn't an inch of excess room...so I am thinking that if I were to try and fit an Inferno GT body on the DM-1 Spec that it would be too small
Alrighty, the Kyosho Inferno GT body finally came in and I measured the wheelbase at just a hair above 13 inches. This tells me that the Inferno GT bodies will fit the DM-1 Spec just fine. Be sure to order GT bodies and not the longer (330mm?) GT2. I do not think any modification is required but will not know for sure since my DM-1 spec is on back order .
