sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
12.31.2008, 09:21 AM
Originally Posted by emaxxnitro View Post
yeah it would be better if neu used hardend shafts. my neu shaft can be ground down with a hand file and also the set screw leaves a mark on the shaft
If it had a hardened shaft, the grub screw would never be able to get a bite on the shaft. Furthermore, if it was hardened, it would be more brittle, making failure more likely. If anything, the shaft needs to be more ductile.
