rootar
rootar's Avatar
01.01.2009, 02:14 AM
^^^^^ he has it right on the money. i go for speed over torque, just make sure your servo saver is setup properly (not too tight or too loose) and your end points are set corecttly and yoru servos should last you a long time. and gear set are cheap compared to buying a new servo when you use high dollar digitals servo with high speed and high torque ratings.
