Thread: 4s MM
01.01.2009, 02:10 PM
Originally Posted by pedeboi364 View Post
i plan to run a ccbec, i 4got to mention. which red wire brianG??
The esc plug that plugs into your rx...remove the red wire, DON'T cut the wire, just remove the wire from the plug end, and you are good to go...don't forget to secure the wire in case you need it again
