01.02.2009, 05:35 PM
I guess the maker and designer of some of the best ESC's don't know what he's talking about...
The braking is regenerative because it has to be -- can't dump that much energy anywhere but back into the battery. (The battery is used as a load, but using a battery as a load mean charging the battery...)
It is not, however, optimized.
Still gets fairly good efficiency up to about 35% braking power -- above that the conversion efficiency gets lower.
PS lower effeciency means heat...
