01.02.2009, 07:18 PM
I'll assume that all your power wires are soldered properly positive for positive, did it ever work properly or is this the first time being plugged in. I have had this problem then it went away, are there connector between the power supply and the charger they may need to be checked, don't over heat the wires when soldering.
