Originally Posted by mohanjude
I will get the eagle tree conencted - I made a bit of a problem by hooking the 2 deans male plugs in series to the controller. So when I hook up the eagle tree I can only meassure the results from battery. can i just double the voltage and assume that the current draw is the same from each plug.
H and M modellbau do a fg motor mount specific for cafs. they trade from a website I called onefive.de
Mohan
I just double the voltage setting on my data recorder when it's hooked to only one pack. Since the packs are in series, each one would be delivering the same AMPs and that's what I really want to see.
