TwzteD
Live Fast, Die Early
TwzteD's Avatar
01.03.2009, 05:34 PM
yea thanks for the pic, btw do you think if i ran anything lower than a 24t pinion on the kb 8xl, will it get to hot? i do plan on making my own mount and see how that turns out. ill probably shave the shaft to 5mm also so i ill be able to use mikes mod 1's this way i got more of a variety, im worried about having the motor hit the transmission with a smaller pinion because it will need to be in closer.
does the kb45 xl motors fit that mount?
  Send a message via AIM to TwzteD
