Thread: 6s set-up ?s
entjoles
01.03.2009, 11:14 PM
i run the 1512 3d on 5s i would assume id be just as great on 6s as it is on 5s, and im running 5s 4000 protek 20c packs with my motor and i can easily make a 15 minute main, it usually shuts off right at 19-20 minutes, and this motor is ALOT nicer to these poor litte proteks than my 1515 2.5d was lipos are consistantly 15-20 degrees cooler, i wouldnt go less than 1500kv on 6s you still want to be in the 31k-35k rpm range so you have the most options for gearing.
thanks for the input , info
