rawfuls
roofles.
rawfuls's Avatar
01.04.2009, 04:00 AM
Very great tips...
I use partitions... Since this new computer I just built only has one IDE port.. And I'm too poor to pick up a SATA 500GB HD.
I have a hard drive just based for pictures, movies, and music....
Apparently, that hard drive is going down the drain, so I have to recover the stuff from there.
I've found that instead of using a internal HD, put the internal in this:
http://search.ebay.com/search/search...fsoo%3D2&fgtp=
Unless you want to boot off the internal like you listed.
What you stated are very good tips, might use em myself... Maybe...
I don't physically separate, as I'm just too poor, and lack of ports.
I used D for my programs ONLY... No music, and whatnot, made that mistake quite a long time ago.
You can just delete the C partition, and reload XP onto the C Partition, than the D partition, but you will need to re-install programs, as the registries are changed..
I have a question for Mr. IT Guy
I have a C/D Drive, 120GB that's crashed, I put it in a external enclosure..
When I try to access my desktop files, it says "Access Denied"... What gives? I think it might just be because since I had a password on my C drive, I guess I should just plug it in via internal IDE?
Thanks in advance!
Originally Posted by Gee View Post
This is a bit long winded I tried condensing it a bit, but wanted to try and explain it so even my Grandma that doesn’t use a pc could find it helpful
Here’s a tip to save you some $$, hours of frustration, and more importantly your time. There are many other ways out there to reach the same goal. This is not the way, just an alternative to the machine. It could take me a couple of hours to have my pc exactly where it was after a virus and a reformat. That’s if it took me an half an hour to find a screw driver to take the PC case off. Went to the grocery store for milk and ran one of my RC for 15 minute. Yeah about 2 hour then.
Little background
There are a few reasons a HD fail. One is due to a physical error of the HD itself. Nothing can be done about that. It can and will die just like you and I. There are signs that are it coming. Some start making more noise or you get Read/Write failure errors from it. There is also some scanning software that also checks for physical errors on the hard drive. The more common and potentially destructive is a virus. It attacks the operating system of you PC. As you know, screwing things up, slowing things down or just plain making your PC useless. Some virus can be removed without a lot off problems. Once a reboot is done on you PC the fight is usually over and the virus has won. That only leaves one alternative. Reformat and reinstall. Virus don’t attack data drives. They go after the operating system. Never have I had a virus destroy the data on any data (slave) drive at home or at work. Got over twenty years under the belt providing IT support at my work place. I will deny knowing anything about pcs to anyone and everyone outside of work, which includes friends or family. Some of you know exactly what I mean. Close to having a little hanging over the belt, but that’s a different battle.
How to get around storing anything on you C: drive.
An external HD is nothing more then and internal HD with a case around it. You can find used internal HDs for only a few dollars. Befriend one of the Geeks, he has access to old pc’s with plenty of HD lying around. There are a lot of different HD connectors like the one I have linked at the bottom. These let you plug a HD, CD/DVD, etc into a USB port. Use the HD and adapter to create backups of data or for just some more HD space. You can have as many of these connected as you have available 2.0 USB ports. They use external power so they are not going to create a problem with you internal power supply. Here’s how I use them and my recover process from a crashed or virus infected operation system.
I have HDs that are attached through the USB adapters that have just one reason to be there. To store information and data files that I want to keep. I use a different HD to store different files. This is how I have it setup.
C: Operation system and installed programs
D: DVD/CDROM R/W
E: DVDs, Videos (mpg, avi, etc)
F: Music
G: Pictures, Documents, Spreadsheets, User Manuals, PDF
H: Downloaded or CD Installation files for programs, CD-Keys, etc
I also have HDs that are not attached but I hook up via USB port to backup the data stored on the slave drives above. In case the hard drive should get a physical error on it and die right now with out warning. Takes just one HD for a backup up F: G: and part of H: Don’t need to backup the program installation files that I have already the original cd for.
Get a plan
I have a small 120 GB HD that I took the time and installed it in my PC as the c: drive. I installed XP on it and got it up and running to the point that I had internet access and all the PC hardware devices worked properly. That HD now is setting on a shelf. If my current 120 GB hd with the operating system gets infected to the point that a reformat is the only cure or it just stops working. I have an operation system HD that will get me up and running on the net in maybe the 10 minute it takes to put in into the PC case. That’s 10 minutes if I reattach it with screws, less if it’s just left to dangle from the connectors.
I have a HD (H:) with all the reinstall programs files on it. Copies of the original cds and programs I have downloaded and installed onto the C: drive. I’m from the days when the cd rom (4x) drive was really slow compared to reading from the HD. It doesn’t take long to reinstall any new programs that I didn’t have or installed at the time I built the backup. I just run them all from my H: drive.
All my data is stored on separate drive then the operation system. It takes a couple minutes to plug the infected drive in as a slave through the adapter and make a quick scan to see if there was anything I inadvertently saved to it. After a couple of weeks (in case I need to recover a cd-key or copy right info from an installed program) I format that drive and place the basic XP operating system on it like the one I just put in and it takes it turn waiting on the shelf.
There is nothing to restore, no 750gb of music, DVD movies, avi files, pictures, documents, etc. It takes a lot of time to copy all that stuff back onto a hard drive. Even more intolerable it would be from the hundreds of DVD data CD that would be needed to back all that up. All of my data is still there when I put the other HD in and started up the pc. It comes up and read the connected drives that I have connected as slaves. Outside of work I have never experienced a virus that has attacked anything other then the operating systems hard drive.
There all kinds of these adapter available. One of these and couple used hd for probably less the 60 buck total and you got a plan .
http://cgi.ebay.com/USB-2-0-to-IDE-S...QQcmdZViewItem
There are jumpers on HD that are used to tell the BIOS of the PC and the Hard Drive itself if it is a Slave or A Master. Master is your C: drive, slave is everything else. The CD/DVD connections can also have a Master and slave configuration.
It’s defiantly worth just getting something additional to store everything on. If your PC came with a 650gb hard drive, You should really consider buying a smaller hard drive for cheap. Install it as your c: drive with the operating system. The 650mb hard drive is much better put to use storing all you valuable data.
Again a virus will attack and disable your operating system. In short separate the data you want to keep from your operation system. Physically separate not create two partitions on the same drive.
Have to post this, the more I removed from it to shorten it up the more I add. See there I go again.
