01.04.2009, 02:26 PM
Originally Posted by FG101C View Post
I can't seem to get the 60mm 2000kv to run cool on 5s (pushing 190+), but on 4s, geared 15/50 the buggy rocks. Still a bit warmer than I like, 170 ish, but my timing is at Low (5), will set it to Lowest (0) and try again. 100% punch control, lowest start power setting, some curve in the throttle.
More than likely just too much voltage for that kv rating- 4 pole motors prefer (in principle, or my head atleast...) to be revved lower & geared taller to make your speed and power really. I think you'd be better of using 4s lipo and gear higher, or choose a lower kv motor (~1800kv region) for use with 5s to reduce current draw.
