MrZ
Assoc.B4,B44/ Assoc. SC8,/Z-car elect/ Z-Nitro
MrZ's Avatar
01.04.2009, 06:01 PM
Metalman can you help with this one. I used the stock center steel diff spur gear (44T) and I'm using the 16T 5mm Pinion that I bought on Monster (Madusa motor.)When I roll the rig back and forth, it make some what of a load metal to metal sound. The sound is coming from these two gears. Could it be that the pitch is off or are they a standard pitch, ie 48. Can it also be the fact that the bottom plate is metal as well, applifying the sound ? Also, when you put together the center diff, did you use the 50% oil the comes with the kit or did you use a heavier one? The reason is, I'm getting a lot of power up front, where my front wheels are balooning at high speeds, does this mean I might need a heavier oil in the center diff? What ever help you can give I would appreciated. Thanks in advance
