chip cross
01.04.2009, 09:52 PM
When I first started thinking about building this little guy I knew it would have Integy 1.9 wheels on it. With that said, I just had to do the jeepcj578 wheel mod to the Integy 1.9 wheels. Whatcha think ??
I drilled out the center caps on the wheels then screwed 2mm x 12 mm studs into the wheel adapter that come with the Integy wheels, 6 2mm nuts will hold the wheel on the adapter. I used red locktite that will hold the studs in place. I am using CAD to Chrome Toyota wheel nuts that I picked up from RPP Hobby.
