rootar
rootar's Avatar
01.05.2009, 01:47 AM
i dunno if youve guys put aluminum rear hubs but i had the traxxas ones and the bearing actaully got loose in one side (bearings were all tight but it was loose where it poped into the hub, traxxas denyed an kind of replacment.....so no im using the ST racing hubs and the bearings almost have to be pressed in, very tight fit, perfect fit and finish, ill definetly be looking to them when i need more parts these are much nicer than any of the other on the market. Just thought id throw that out there because once you start jumping and running them good your gonna need better hubs.
