Originally Posted by jzemaxx
Well all I need is two tray's to be able to hold and protect a max of 2 X 6S batt's and I can add fillers for the smaller batt's.
Have you looked at the long versions of the 6S lipos packs JZ? The CEN's chassis looks long enough to fit one on each side. That way you will keep them as close as possible to the chassis. The only problem is that you'll have to make the battery holder yourself.
