Thread: need help guys
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
01.05.2009, 10:23 PM
I have found that steering tends to be a lot less prone to interference or bad signal then the esc. My MM does exactly what you describe when it is about 30m away. The receiver antenna has been broken so the range is crap. It's not a problem most of the time. The MM seems to hold last throttle position momentarily before dropping to failsafe.
