Hey Lito,
if the hole in the center of the strobe slipper is 8mm you can use it...but you will have to use my pressure plates!...the chassis comes complete with RR slipper,slipper pads and custom pressure plates!!
....i am using the smaller RR slipper(66-70 tooth only)...did this answer your ??
