himalaya
himalaya's Avatar
01.06.2009, 12:29 AM
The left solder point of the coil is the BEC output, as shown by the red frame in this picture. You can solder the read wire here. But due to the large copper area under the coil, you need to set a higher temp on your soldering iron.
....What a Blue Sky....
