01.06.2009, 03:42 AM
Originally Posted by marzac2 View Post
No. The motor would only be working as a "generator" while you are "free rolling".
The moment you apply brake, you are asking the motor to stop a 13lb vehicle. And this comes at a cost = energy.
Do you believe that making a motor alone stop a 13lb vehicle, that it would not spend any energy doing so? Are you saying that it would actually re-gain energy making this happen?
Yes that's what he's saying. Have you read the entire thread? regenerative braking is used. You cannot lose energy, only transform it. The stable temps on the mmm esc prove regenerative braking works, otherwise your esc would cook because that stopping power has to go somewhere, either as heat on a brake disc, heat on a blown esc, or back to the battery in the case of the MMM. Eagle tree graphs prove energy is regained.
