jhautz
jhautz's Avatar
01.06.2009, 01:42 PM
Only problem is that if you get dirt or dust in the sticky side it never will work again.
Most adhesives only work if the surface they are sticking to is clean. Clean it.... Stick it.... and forget it. You cant take the glue off and on and expecti it to work. Thats why i like the dual lock. The glue sticks really well as long as you dont have any edges hanging loose or off the side of the part you are sticking too. It wont come off unless you want it too, but you can still get the esc off. I leave a small corner under the bottom of the esc with no dual lock on it then I can use that to put a little scredriver under the esc and pry the dual lock apart.
to make it...
or break it...
Silent...But Deadly
