rchippie
rchippie's Avatar
01.06.2009, 03:17 PM
Have you tried the RED threadlock??? Make sure the socket is in good shape on the screw or you might not get it out.
I would advice against using red locktite . It will stick very very well & make it tough if not impossible get the screw back out . If you do this & the screw wont come out . ?Take your soldering iron put it the highest setting & touch the screw for a minute or so . you should know be able to back the screw out .
REAL MEN RUN BRUSHLESS
