big greg
01.06.2009, 05:39 PM
Are you using cap-had screws now? Honestly, you are #1 that I have heard of with this problem. Maybe the threads in that particular hole are worn out(?). Try rotating the motor to the next set and see if you still have a problem. I do find it hard to believe threadlock didn't help. Did you let it cure before the run?
out of 10 medusas ive seen run, 9 of them had thread problems. the aluminum/taps they use are crap. i usually just tap them to a bigger size right away, i have 6/32's in the motor im running now, and they loosen up after a race, not to bad tho
