sikeston34m
sikeston34m's Avatar
01.07.2009, 12:21 AM
IIRC, the recommended charge voltage is 3.6 volts per cell on A123. 4X this is 14.4 volts.
I remember charging 4S2P A123 with an automotive type charger at 10 amps. It could even be cranked up to a 20 amp charge rate. The cells didn't seem to mind.
After the charge cycle completed, the voltage would settle back some, but with good results.
I'm not sure what the deadband or upper and lower voltages of most automotive type regulators is. But the charge termination voltage of the charger I used was 14.5 volts. In other words, the alternator does satisfy when the voltage comes up to 14+, and doesn't kick back in until voltage gets back down around 13.0 volts or so.
I've often thought about building an A123 pack like this. The longevity of it could be really good.
4S10p could produce a 700 CCA setup. This would yeild a 23AH Battery.
In thinking about this, a good Deep Cycle Battery averages 100ah.
The downside to all of this. It would require 40 cells. Gets expensive really quick.
I'm tempted to build a smaller version for testing on my 4 wheeler maybe.
