sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
01.07.2009, 11:10 AM
Not true losses increase with square of current W = I * I * R...
Yes, that's correct. Higher voltage will be more efficient.
You can have all the watts, but electric motors also makes power from torque and that's where a lower Kv motor (Brushed or Brushless) will have the advantage.
Torque produced by a BL motor is a function of the can length. Once you saturate the magnetic field, they all make the same torque. So a 7700kv can make the same torque as a 4600kv, provided you can supply enough power to saturate the coil. Once it's saturated, all the power in the world won't change matters. If you want more torque, you need to go to a longer can.
This is further backed up by Castle's site:
A high power capable brushless motor in electrical engineering and physics terms, has unlimited torque. We live in “the real world” so technically for us that’s not totally true, but – a brushed motor has a torque level that due to its design has an upper limit, regardless of how much power is being applied to it. That limit is low enough that you can see it clearly on an average track On the other hand, a high power brushless motor’s limit to torque in an RC vehicle is not within the bounds of the motor itself so much, but rather falls on the ability of the battery to deliver current to it. We generally don’t describe these motors in terms of “one has more torque than the other”, but rather “the 7700Kv motor is faster and draws more current than a 5700Kv motor in the same vehicle”. It draws more current, because it’s making the car go faster and doing more work than the 5700 motor is. As long as the batteries used are very good at supplying current without an excess of voltage depression (low internal resistance is good) both motors will appear to have the same torque, even though one is much faster than the other.
and this:
So think of torque as a function of battery capability only.
So low kv does not equal more torque.
