01.08.2009, 12:02 AM
Originally Posted by Krawlin
Well now the next step in this build would be to solder on my 6.5mm bullets on the motor and ESC, and use my braided metal wire shield on the motor wires and the steering servo wire, and replace the chassis with the new plastic one I got (Same as the one on there, but the current one is cracked at the mounting points up front), then install the front FLM hybrid bulk.
Notice how the BEC is not visible? I want to see who can figure out where I put the BEC. Ryan, Travis, Ben, and Ian, you are not allowed to say because I think I already told you guys a while back.
Is it under the ESC?
