marcus
marcus's Avatar
01.08.2009, 12:07 AM
I haven't found the pinion yet. SDP-SI doesn't have them, neither does McMaster, and Kershaw would probably want $25 bucks for 1. I'm thinking since 5mm/32P pinions are abundant I might just have to find a motor that has a 5mm shaft and a 30mm bolt pattern and is no more than 45mm in diameter... Now, where would I find one of those???
Neat project but I'm confused a little. The hold up is the pinion which you suggest Kershaw has [or could make] but you're baulking at $25 ??
Seems an odd point in the project to get cheap
Get Kershaw to make one or just open a 5mm one out
