florianz
01.08.2009, 08:28 AM
what pwm-setting did you try? i experienced that w. a higher pwm coggin disappears, just like timing. first put the pwm higher, then try different timings, I use eg. 7deg. for a two pole, as long temp. is ok. The cables/wires aren't too long?
what I've read about the small ezruns it seems that at least these esc's are quite ok.
I dunno if that helps, just a try.
I like the three big 1000er caps, that looks solid. size DOES matter...
