New Neu 1400 series motors
othello
HV basher
New Neu 1400 series motors - 01.09.2009, 07:20 AM
It seems as if we have a new option when it comes to powering our buggys, lighter truggys or monsters: 1400 Series Neu motor
It features the smaller more common 36mm diameter making it possible to fit those smaller pinions which might have led to clearance issues when fitting a Neu 1515. It uses the 1515 rotor but given the smaller can diameter and a smooth can will not be as powerfull as a Neu 1515 ... or atleast will heat up faster then a Neu 1515. So it might be an interesting choice when a Neu 1515 is just to powerfull. Hmm ... will it fit powerwise between a Neu 1512 and a Neu 1515?
So what do you all think about this new motor option?
Would be interesting to know if the endbell is also closed like the frontbell seems to be.
