Sammus
Sammus's Avatar
01.09.2009, 09:54 AM
Originally Posted by mriccucci View Post
The only issue i see is there's nothing moving the water around. The water needs to flow to do any sort of water cooling.
Apparently it has a pump and a dodgy radiator.
The cooling system has a pump that is powered by its own LiPo pack, that sends water through a cooling jacket on the motor and speed control. The water then passes through a coil of metal tubing that is further cooled by an electric fan.
