01.09.2009, 11:02 AM
rated 35a 11.1v (388w) shorter than a 540, but with a 5mm shaft(i know a guy that can have it turned down for you)
http://www.puffinmodels.com/product.php?prod=818
woops, its 12 poles. popped up on a 6 pole google. I'll look again.
12 poles is ok, looking for a torquey motor. I may go down to the 22/10/8 as it is around 1500kv and shorter. The can length is my main spec I have to meet as space is at a premium...
Here you go, this meets all criteria except for the 3.2mm shaft part, this one has a 5mm.
http://highendrc.com/index_eproduct_...products_id=50
Bit too long, but thanks!
