Originally Posted by BrianG
The Ofna single speed spur setup uses the 51T spurs: http://www.rc-monster.com/proddetail.php?prod=ofn30110
Luckily, I happen to have a few from the old days when using an emaxx tranny with strobe slipper setup was common.
Note about the Ofna single speed kit: It does not come with support bearings or outdrive cups so you need to get those seperate. Also, my kit did not come with the needed grub screw, which is 5mm.
I'm not gonna be needing that stuff, Im using the clutch bell and the two speed trans in my setup with mechanical brake. But thanks anyhow.
