01.09.2009, 02:30 PM
That is true; liquid does carry heat away faster than air. However, by the time you add this type of cooling to a cheap system, you have A) created more weight, which creates more load and heat, B) spent as much as a more efficient setup that doesn't need any exotic cooling, and C) added a level of complexity and possible points of failure.
