portyansky
01.09.2009, 11:51 PM
Did you lock the tranny, or are you using the 2 speed setup?
2 speed
its great, with the slayer tranny you have alot more options for gear ratios
with my 1515 2.5d on 5 cell i had monster bottom end but was limited to about 35mph with the proline tires
with the slayer tranny the top end is about 45mph on 5 cell
and i have almost no mid throtle lift so it worked out great in my race revo.
the only down side is traxxas hasnt put out a diff for the slayer tranny
did you get the slayer tranny case as well? I hear a cd is comming.
What gearing are you using? How are your temps? And are you using the wide ratio?
Thanks.
