Originally Posted by sikeston34m
Just about every brushless motor will behave this way.
If you are turning it by hand, it's generating a small amount of electricity. When you touch the wires together and turn it, then you short the amount being generated.
i understand that. but im not shorting them . its shorting inside the can.
i can see it. the blue input wire is melted.
