Originally Posted by suicideneil
Did the insulation actually melt, or did it wear through and cause the wires to short against the can, then the heat caused the surrounding insulation to melt further- thats what Neu will probably look closely at. The burnt wire smell probably means the enamel coating on the wires is toast- motor is probably a rightoff saddly.
yeah it looks to me as the windings are probably shot. the wires are melted (the copper is melted) hope i can get it replaced.
