Ran the truck today at school(robotics) ran pretty well aside from a few things- the new spur gear is louder then the humongous 66t,My motor mount came loose and almost totaled my pinion(my fault-loctite time). The only real problem was the front walls of both battery trays broke out- they were held in by 2 little m3 coarse screws. both screws pulled out when i came off a jump and landed nose first...perpendicular to the ground.
2 part epoxy should do a better job no?
The truck turns a hell of alot better with the 0 offset wheels and the weight better distributed.. Now I just need to get some bent tie rod ends to clear the wheels and get my steering throw back
