Mozzy
Mozzy's Avatar
01.11.2009, 08:52 AM
that is exactly the reason. this is advertised in all of Teknos conversion ads; that mech. brakes result in lower temps. your motor has to work a lot harder to stop a 9lb truck by spinning in reverse than it does when you let a servo do the work.
btw, the proof is in the pudding. 4mins is mins. more than i have heard from anyone seeing increase the other way around. granted you would get a more accurate depiction if you recorded say...10 run times of each setup with the exact same setup.
Mozzy, do you always track your runtime? if so, when you had motor brakes did your runtimes ever vary by more than 4mins? if so, then it is simply just that much variation exists in your runtime regardless of brake setup. let us know more about how you did your test? more than once? just one time?
I have timed my runs from the start (which isn't that long ago) to see the difference between the gearing/motor & battery chosen.
I'm using Zippy 5S packs both 4000 & 5000 with a 2.5d in my CRT on a 15t pinion.
The difference between the two packs is 5mins.
I have a timer on my 3PKS & as soon as I hit the track or accelerating I hit the start button. If I roll I stop it untill I begin accellerating again. As soon as the pack shows signs of dumping, I stop the timer.
Losi SCTE SC4 Pro 4000kv, Tekin RX8, 2S
MP7.5 Kanai III Tekno Neu 1515/2.5D 1700kv MM 4S
LST 2 Carbon CC 1717 1Y 1580kv MM 6S
Futaba 3PKS Spektrum Pro
