01.12.2009, 01:45 AM
Personally I would go with a enerland based pack with 5s 5000 25c specs. You could also do the 4500 30c 5s pack. Anthing less and you may be overworking the lipos. 15c is too low unless you go up to 8000mah.
As for the 25c vs 30c debate, the 30c seem to run warmer, but do not seem to mind the heat.
