01.12.2009, 11:47 AM
cogging is inherit to sensorless brushless at low speeds. You can lower a tooth or two on the pinion, raise start power, or give it a good kick before you take off. All should help, but may not completly eliminate low speed cogging. These systems were designed for high speed, and not "crawling along"
