11.27.2005, 06:14 AM
the bearings are the same that are used at the wheels.
And no, i did not just shimmed the diffs, i made 4 square blocks at the end (with HB cups this is not needed) and made the diameter of the crosspins smaller, to fit in these blocks..
Shoot for yourself, if you want aluminium cups, they are more expensive, and now you are complaining about the price of two bearings.. It's only a hint to keep the diffs going. ;)
You also need to shim the diff on the outside.
