01.13.2009, 06:41 PM
Simply add the motor front end thickness (~4-5mm) and add in the thickness of whatever mount you are using.
Actually, I insert a really long screw into each hole and gently turn the screw in by hand until I feel resistance (the coil). Then, I back out a turn or two and then mark the screw threads where they go into the can. Repeat for the other 3 holes and use the shortest measurement.
