Krawlin
Got brushless?
Krawlin's Avatar
01.13.2009, 07:36 PM
I suggest you sell the MM while it is still alive and invest in a MMM- you won't regret it.
Nah, I want to see if I can get this thing to work. Not just going to take the easy way out this time.
it is your connectors, i told you that already, silly
Yeah, yeah..... I just hope the new connectors fix the problem so it wont happen again for however long the MM is around before it gets fried from by my motor.
I had the same issue with 2 of my MM's awhile back. Solved it by disabling the on/off switch all together and bought my first set of TRX plugs to replace the deans. I am very happy in doing so. They have more contact area, more confortable, more grip, no heatshrink...
How did you completely disable the on/off switch? Just solder the wires together like I did?
Monster GT Conversion
