What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
01.14.2009, 10:59 PM
From what i have read it is the lubrication that determines the speed of the bearing more than anything.
True. The grease causes a lot of friction at high speeds which can overheat the bearing. Oils and/or synthetic lubricants cause less friction, and therefore less heat. On the other hand, grease is better at keeping dirt/debris out of the bearing.
