coolhandcountry
coolhandcountry's Avatar
11.27.2005, 12:46 PM
From my experences. you can run a brushless motor under geared if you run a low cell count and a high turn motor. This in turn keeps the rpm down and the heat factor. The sensored is a good option. May look at the aevox motors for that or novak. Keep in mind of what shaft you will need as well for pinion selection. good luck on project.
Peace!
Country
Help support the
Rc-Monster
Buy here
