pasan
I <3 RC
pasan's Avatar
01.16.2009, 01:40 AM
I would select the 2000kv for running on 6S. You'd still be within the operational limits of the motor, and I find that Medusas' sweet spot is between 35k and 45k rpm, at least thats when my 36-50-3300 really becomes lively. Also, when you're running 6S the current draw is less and as a result everything runs cooler anyway, same reason why you see a difference between 5S and 4S too; if you're pulling the same amount of wattage from both setups, the 5S setup will obviously have a lower current.
E-Revo - Mega ACn 22/45/1E MMM 6S
E-Maxx - Feigao 7XL MM 4S
AX10 RTR - Stock :D
Micro-T - Losi LiPo upgrade
Mini LST2 - Discarded. Useless POS.
1/8 Scale Baja Bug - Medusa 36-50-3300 eZrun 60A 3S
