01.16.2009, 07:22 PM
Originally Posted by asheck View Post
Thats true.They are also a well built pack.I think there turd polishing works on most.
They do fit most std trays, but most newer electric vehicles are setup to run 7 cell packs, or have a longer tray to allow the 6 cell packs to be shifted for weight distibution
As far as assembly of the cells they are no better than most other packs. They do not use double sided tape to hold the cells together, and they only have one layer of shrink on the narrow sides. Tabs are crimp/welded together. The lack of matched cells is a definate assembly issue to me.
As far as customer satisfaction goes, if you have nothing to compare MA packs to except cheap stick packs you will be blow away by the performance. It is hard to say that they are the best when you have no comparision (I had to quit going to nitrokillers cause everyone there was Ma biased with no basis for their claims)
