01.17.2009, 09:23 PM
4s2p A123 fits, but thats only equal to 3s lipo, when what you want is something equal to 4s-5s lipo- thats 10-12 A123 cells...
Zippies perform pretty much to their advertised specs- voltage will drop under load, but with 6s lipo and a 2200kv motor you will naturally need to gear lower than normal (when running 4s lipo with a 2200kv motor for example), so the reduction in work load for the motor (lower gearing = more torque and less current draw) will help the batts somewhat. There are also 25-35c zippies that will work, and the newer versions of the zippies with a blue label on the blue heatshrink (especially for planes I believe), check the dimenions and specs as they might be better. You wouldnt be dissappointed either way for the price, or there are Mikes new lipos in the store that are performing very well (unbranded ones).
