01.18.2009, 01:05 PM
Originally Posted by killajb View Post
Why not just use LST shocks and put 25mm of fuel tubing under the shock piston?
Because then I wouldn't have the suspension travel anymore. IIRC, there is 45mm of travel, and if I use a 25mm spacer, travel would be reduced to 20mm.
The muggy shocks are what you want. 138mm center to center on the eyes, 100mm compressed. Diameter with springs is just under 35mm.
I was really gonna go this route, but I heard something about weak shafts. IIRC, there are Ti replacements, but wasn't sure if they were different lengths. Can you get Muggy shocks with aluminum shock bodies and Ti shafts pre-done, or do you have to buy the shocks and upgrades? I looked but didn't find anything. And I don't know what cross-fits between the Muggy/LST/Aftershock.
Originally Posted by pedeboi364 View Post
try some savy shocks
Those would be perfect for length/travel, but I want bigger bore.
Someone had a nice set of aluminum LST2 shocks on ebay (4 for $50), but when I found out there were 165mm long, I couldn't use them.
